Hope some one can help with mapping Ipod Touch
I am using puredata MidiYoke and TouchOSC and my custom screen
I have been very successful so far, but like all good things at some point you hit a wall
I have mapped allmost everything except :-
automix button, effects buttons and loop buttons
I have come to the conclusion that it is with the 'simple midi mapper', as if i map my commands to a Keyboard key it works, but does nothing when mapped to the ipod buttons
ie
deck 1 effect "BeatGrid" active
works fine if map to key alt-b, but does nothing if map to touchosc either as push button or toggle button, Virtuall DJ picks up the key when i tell it to learn, but does not do the effect.
Anyone got any ideas, as this would complete my remote controller.
ie
Posted Sun 05 Dec 10 @ 10:24 am
deck 1 effect "BeatGrid" active toggle
What is the command you are using for the cue botton?
thanks,
David
thanks,
David
Posted Fri 04 Feb 11 @ 2:53 pm
