Hi All!
I have a problem... During the installation of the VDJ 7.0 the program claims the following: "the procedure entry point DecodePointer could not be located in the dynamic link library KERNEL32.dll"
What is this??? And when it finishes the installation and I try to start the program it shows this again and it's impossible to use it.
Please help!
Thanks in advance!
Please help!
Thanks in advance!
Posted Sun 05 Dec 10 @ 3:39 am
What OS and Service Pack are you using?
Posted Sun 05 Dec 10 @ 5:05 am
I use XP.
Any ideas?
Any ideas?
Posted Sun 05 Dec 10 @ 5:41 am
I asked you two questions... what XP service pack?
Posted Sun 05 Dec 10 @ 8:25 am
Sorry for the late reply but I was away for a few days. So, I use more notebooks and I have one only for music. This has the service pack 1.
Do you think this could be the reason?
Posted Thu 09 Dec 10 @ 2:57 am
DecodePointer() was implemented by Microsoft in Windows XP SP2. I can't believe anyone would be running XP SP1!
Update to XP SP3.
Update to XP SP3.
Posted Thu 09 Dec 10 @ 3:37 am
I think the reason is that dodgy version of VDJ you are using.
Posted Thu 09 Dec 10 @ 3:47 am
Well I don't think there would be any problem with the type of VDJ because I could install it on another computer so it must be OK.
But the service pack... I don't know... Can I purchase the SP 2 somehow?
Posted Thu 09 Dec 10 @ 9:03 am
WoW, just.....WoW!!!
Posted Thu 09 Dec 10 @ 9:08 am
I just don't want to get the SP 3, belive me I have my reason... :-)
Posted Thu 09 Dec 10 @ 10:32 am
If you download are install this:
https://virtualdj.com/download/free.html
Do you have the same problem.
XP Service Packs are free and the only reason to not update is if you are running a pirate version of windows....
Posted Thu 09 Dec 10 @ 3:06 pm
The same problem with this version as well... :-(
Posted Mon 13 Dec 10 @ 2:16 am
it seems to be the only way to run VDJ, so make your choice !
Posted Mon 13 Dec 10 @ 6:29 am
Indeed. Update to SP3.
Posted Mon 13 Dec 10 @ 1:44 pm
well I had the same problem what I did was install sp3 and it was fixed.I use xp pro
Posted Wed 12 Jan 11 @ 6:03 am
