Hi guys.
i got this huge problem.. i just let the VMS4 arrived into my house, and i have sit the last few days to sped on this machine.
but i got serval problems.
i just the normal soundcard i got in my computer and it sounds great with the VMS4.
but one big problem is that i dont know how to use the midi controller and i know there is 100 of forums in here with same problems and i have read almost all of them and i cant figure it out.
The EQ dosnt work eaither, and i know about to pres the cue buttom number #4. but it dosnt work.
Asios dosnt work eaither, and i cant find any places it say how to use it.
Pleas help me, im new at this point.
Kasper P.
Kasper P.
Posted Wed 01 Dec 10 @ 10:18 am
Hi Kasper
Its always best to add your Pro serial number to your member profile so you get all the benefits and recognition as a Pro member should get.
The VMS 4 is an analog mixer by default with internal sound cards that can be assigned just like an external mixer.
It can still be assigned and used like a midi mixer using the internal mixer of the software, but it must be done manually assigning each feature you wish to assign or download one of the mappers in the download section once you have registered your Pro version serial number.
Hope this helps
Rick
Hope this helps
Rick
Posted Wed 01 Dec 10 @ 11:46 am
