Hi, I'm currently using VDJ 7.0.1 and when I broadcast, it freezes, and that's driving me crazy! I don't know how it works with vdj 6...
I use lysten2myradio.com for broadcasting. Everything else is fine(the sound, and people can listen without any poblems) but, but, buttt!!!! When I cue, play or move any fader, it freezessss!!! Sometimes VDJ works fine and does not stop working at all(I mean freezing)
Note: This only happen for a few seconds, it doesnt crash!! It just freezes for a few seconds, from 4 to 15 seconds. And it seems like my internet connection that is a lil slow, is causing this!! I also close a lot of apps and turn off the anti-virus.
---------------------Another question--------------------------¿?
I see many people have old laptops that are not so good(I mean the Ram, HD, etc...) And VDJ runs excellent! Then why do my laptop that have 3GB of Ram does not run VDJ fast or normal at best quality??? I have to set everything to best performance. :S
It uses almost 100% of CPU and vdj gets slow, even at best performance which is poor quality, it gets slow sometimes! So I have to close everything! Even the internet I have to take te cable out if I want the best performance.
I'm sorry if you guys dont get something, my language is spanish but I think you guys may have the best answer here! ;)
Thanks, Reigar.
Toshiba A305D AMD Turion 64 X2 mobile technology TL-60 2,00 Ghz, Windows Vista 32 bits.
3GB Ram and 184 HD.
Thanks, Reigar.
3GB Ram and 184 HD.
Posted Tue 30 Nov 10 @ 4:37 pm
