hi ive got a hercules rmx at the mo and use with vdj , also have a technics deck plugged in 4 scratching etc . i want to get a newer controller , i like the look of the vestax typhoon i know i wont be able to plug in any devices into it , but is the scratch platters any good ? are they the same ones that are in all the vestax midi controllers ? also i dont see a cue to master headphone mix on the unit which is a real same but would i be able to remap say an eq that i would never use like the high to do this in vdj ??
any help or advise with this controller is appreciated , just seems a good price for a vestax controller
Posted Tue 30 Nov 10 @ 12:17 pm
It all depends on YOU really. My buddy has a Typhoon and it's fun to play around on, but I much prefer my VCI-100 for my gigs. But it all depends on your preferences. The VCI-100 doesn't have an audio card in it (which I prefer).
Do your research and try one out at the music store, before you make your decision.
Posted Tue 30 Nov 10 @ 12:44 pm
I had a chance to touch and feel the Typhoon, and I think it's bad-ass for a interfaceless controller. I like the craftsmanship of it including but not limited to the relatively tough plastic build of it as well as how the platters feel. Making contact with platters, touching them with my fingers, i.e., was very satisfying, as the grip was really good, and I just can't think of why this controller would not be good for scratching. At 300 USD I think its a pretty damn good unit.
Posted Tue 30 Nov 10 @ 2:07 pm
thanks for replying , does any1 know if i could map a knob on the controller (or any midi controler) for cue mix cue --> master output through the headphones . my rmx has it but the typhoon doesnt :(
not really mapped anything on controllers
Posted Wed 01 Dec 10 @ 11:04 am
In VirtualDJ Pro, you can change the mapping of a knob, button, etc. to any function of your own choice.
E.g: Map a knob you don't use to headphone_mix
Posted Wed 01 Dec 10 @ 1:32 pm
