Forum: Old versions
Topic: Herculex RMX Sound Card Noise
Hi I have Hercules RMX with a HP Pavilion. The issue is that when connecting and using the RMX soundcard, i had some noise, like popcorn noise on speaker. When connecting the auido thru the PC mini jack, everything sounds OK.
I used the RMX on another PC (Vaio) and have no problem with the USB. I had the hercules to a MIXER, but if using the PC sound card, i loose the headphone monitoring capability and also the feader of both dishes of the RMX.
The HP PC used to had VIsta, and I upgrade to Win 7 to verify if the problem was fiz, but no luck.
Any alternative for me?
Joseph, PR
Posted Sat 27 Nov 10 @ 1:49 am
Stuttering, popping and other sound glitches are normally caused by performance issues with your computer or incorrect configuration in VirtualDJ.
Please see https://virtualdj.com/homepage/jpboggis/blogs/4094/Common_performance_issues_and_solutions.html for a list of common causes and their solutions.
NOTE: The RMX uses low latency ASIO drivers whereas your computer's internal card will usually not, so the internal card will be less likely to be affected by performance issues.
