hey guys i just recently switched to using timecodes but for some reason i cannot get anything better then %5 quality and it isnt even steady it will jump very fast between 0% and 5%. The timecode also is a square shape it isnt two circles if that helps. Also I am using virtual dj cds that i burned off the website. Im running VDJ 7 with an Audio 4 DJ to a pair of CDJ 800s on a Macbook Pro.
Also i tried it on my PC and it worked perfect 100% right away.
Posted Thu 25 Nov 10 @ 3:30 am
i forgot to add that i have to put the timecode setting on to thinking its running a serato cd to even pick up any quality it picks up 0% if its set on a Virtual DJ cd, which is what im using
Posted Thu 25 Nov 10 @ 3:33 am
bump
Posted Sun 28 Nov 10 @ 4:13 am
I have an Audio 8 and I wasn't able to use it with Mac + Timecode. That's why I was force to buy an Hercules MK4 just to make my timecode work when I first had my Imac & MacbookPro...and eventually upgraded to Denon DN-X1600 for a more Pro-Sound quality.
It's a driver issue that Native Instruments didn't bother resolving up to now. If you don't have any plan to get a new audio interface, then bootcamp will be your best bet (install Windows into your Mac and run VDJ in there).
Goodluck!
Goodluck!
Posted Sun 28 Nov 10 @ 6:03 pm
thanks for your response ill try putting windows on my computer
Posted Sun 05 Dec 10 @ 7:21 pm
