When I record a sample it's not loud enough. How can I make samples louder? EASILY!
Posted Wed 24 Nov 10 @ 1:57 pm
not if you plan on mixing internally. with an external mixing it sounds better because of the gain control. Another solution would be to export your sample into sound forge and increase the volume. I use the bbe sound processor plug in to make the sample sound full.
Posted Wed 24 Nov 10 @ 8:35 pm
