Hello everyone,
I've sent an email to support but no luck in getting any answer, which is very frustrating.
Here's my problem:
I've recently upgrade to vdj7 and now I can't get my USB mic work with the new setup.
I've tried all the suggestions provided to different answers on this forum, but no luck.
I have a YETI USB mic. Using a HP Pav 9700 series laptop. It used to work with vdj 6 when you actually could see MASTER+MIC on the CONFIG.
I tried ADVANCED option on vd7, but it's way too complicated.
Any help would be greatly appreciated.
Thanks,
UD
Here's my problem:
Thanks,
UD
Posted Fri 19 Nov 10 @ 1:53 am
I don't have the software in front of me, so I can't try. I would try config again. It may not be as complicated as you think.
Posted Fri 19 Nov 10 @ 3:32 pm
uuuhhhhh , didn't know LE users had PRO 7 ......
lucky you
the advanced sound config is one of the greatest things since fish net stockings ....
and , i think it's very straight forward actually ....
you can actually click on the arrow on the first box that says "deck 1" or any deck #
and select your microphone (as long as it's already installed) where it says "microphone"
VERY complicated .......... then proceed to choose which output you route it to .....
channel 1,2,3,4,5,6 ..... i hate these huge numbers ......
click "apply" and "ok"
ok?
Yeti ?? i think that's a Blue ...... there mic's are great but there support for there USB mics is terrible/nonexistent
lucky you
ok?
Posted Fri 19 Nov 10 @ 3:59 pm
