My setup:
Virtual dj pro 7 and 6.2 (both versions are showing the same problem)
Hp dv 8000 Intel Centrino Duo t2450@2ghz, 4gb ram ddr2, 2x500tb, winxp sp3 32bit
nVidia Geforce Go7600 integrated ramdac 256mb
My controllers m-Audio Xponent and RMX using latest firmware and asio drivers
The problem:
Audio pops when playing videos, and using a video skin.
The pops show when the contrast in the video switches from dark to bright.
This happen only when I use a video skin with the 3 video windows built in.
Changing performance settings are not helping.
This happened with all my video file formats, vob, mp4, wma, flv, etc.
Deselecting the “use hardware acceleration” check box under video settings helps, but is increasing the processor workload to about 80% and the video output quality suffers big time.
Mixing the same video files with an audio skin works perfect even if I output the video to my projector and have the "use hardware acceleration" checked.
Now is hard mixing video blindly, don't you agree?
Can anybody please work on a solution for this?
Did any of you encounter this problem?
Any pertinent input will be highly appreciated.
Happy Spinning!
Lex
The problem:
Happy Spinning!
Lex
Posted Wed 10 Nov 10 @ 6:08 pm
ANYBODY!!!
DEV TEAAAAM!
PLEASE HELP
on an another note here is something that you might like just click on "sound and hearing"
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
let me know if you liked it
DEV TEAAAAM!
PLEASE HELP
Posted Sat 13 Nov 10 @ 11:15 am
