Hi guys,
I have a dac 3 controller and I need some help please.
I want to use the mix now button to toggle between br zoom and decks in vdj7.
I have managed to get it to go to br zoom once i push the mix now button but when i push the mix now button again, it want go back to decks.
what do I need to do please
kind regards
Jay
kind regards
Jay
Posted Mon 08 Nov 10 @ 1:43 pm
Please post details of what you have mapped the button to.
Mapping it to browser_zoom should do what you are looking for.
Posted Mon 08 Nov 10 @ 4:42 pm
Hi jpboggi,
thanks for the help. It has nearly worked.
It now toggles between browser and zoom on the mix now button but I am after it going to br zoom. So that I can see the decks playing at the top, to ensure that the song is not about to end.
I am using the Rusty 4d skin.
I have tried to change the name from zoom to br zoom but this has not worked
any thoughts what I can do
kind regards
kind regards
Posted Tue 09 Nov 10 @ 2:20 am
This is a skin function that has been added by the skin author, so you need to follow the skin authors coding. In this case, map:
That should do it I reckon.
skin_panel "br4" on ? skin_panel "fab" on & skin_panel "decks" on : skin_panel "z4ab" on & skin_panel "br4" on
Posted Tue 09 Nov 10 @ 4:50 am
SBDJ,
you are a genius!!!!!
it's worked a treat.
THANK YOU so much
kind regards
THANK YOU so much
kind regards
Posted Tue 09 Nov 10 @ 4:58 am
