Forum: VirtualDJ Skins
Topic: Touchscreen Skin (interactive ... lets build it together !) - Page: 2
Product temporary unavailable.. it seems you bought the last piece..lol ....ok ... . so what is the native resolution for this?
I dont use the jogs for scratching, but I do use them.
For pitch bending or fine cueing or navigation through the song?
For pitch bending there will be bend buttons
There will also be scratch wave for fine cueing and navigation
You may also use the rhtyhm wave or song pos for navigation.
Jogwheels will need large space in the skin, and will make buttons smaller.
Check your pm.
Gotcha!
