I have had my Hercules RMX for a year now and not had a single problem with it. I downloaded VDJ7 and noticed freezing and glitches so I went back to VDJ6...now when I try to set my sound card to the RMX it wont come up...I am able to select 'mono separated' '2 cards' '4-out'. I've never had this problem and I hope there isn't something wrong with the RMX internally...I have a mac by the way....if anyone could help that'd be great!
Posted Wed 03 Nov 10 @ 9:00 pm
My guess is that by installing V7, you probably overwrote the preferences file, so v6 is not able to read it properly, so not all options are available anymore.
I would delete the Virtual DJ folder (In Documents) as well as the preference file (Library > Preferences > com.Atomixproducts.Virtualdj.plist ) , then reinstall the versions you want to use.
Posted Thu 04 Nov 10 @ 7:57 am
I uninstalled as well as doing what you instructed....still nothing. I'm really at a loss here. Has anyone else experienced this?? In the sound card option on the right side I am able to choose Hercules RMX console but on the left it does not sow up.....someone please help....
Posted Thu 04 Nov 10 @ 5:44 pm
Are you using the latest drivers from ts.hercules.com? I have not had a problem since updating, but i stay as up to date as possible with hercules.
Posted Thu 04 Nov 10 @ 7:32 pm
Where do I find the latest driver...
Posted Thu 04 Nov 10 @ 10:22 pm
Well, the Hercules support site, of course:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
You want to make sure your DJ Console is installed correctly, as described in this document:
http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
Posted Fri 05 Nov 10 @ 6:33 am
