allright Im trying to turn the fader (f1) into a crossfader +0.03 / crossfader -0.03 problem is that when mapping it sees the the fader as a single key (0-CC1) is there away around this?
Posted Tue 02 Nov 10 @ 5:08 pm
Add this:
param_greater 0% ?
or
param_greater 0 ?
depends on the numbers your using.
param_greater 0% ?
or
param_greater 0 ?
Posted Tue 02 Nov 10 @ 5:22 pm
I don't know if i don't understand...or vise versa...
I have a crossfader on my midi device its recognized in VDJ7 as 0-CC1....is there like a mapping command that can make it act like a crossfader? Using pads its easy but it defeats the purpose of having a fader. (for buttons i use crossfade -0.03% & +0.03%)
crossfade param_greater 0% ? & crossfade param_greater 0 did not work.
Posted Tue 02 Nov 10 @ 7:58 pm
Doh! used crossfader_slider ...works fine (thanks for your help)
Posted Tue 02 Nov 10 @ 8:33 pm
