I some how screwed up my external harddrive and lost all my music on my harddrive. I have a gig tomorrow(Halloween) and it's my cherry popper( first one) luckily its just for a friend(free) but it's a yearly thing with their family and friends so I don't want to look like a fool!!!! so I'm going to have to use my iTunes library but how do I get bpm to show next to the song in the folder where you scroll thru your list?
Thanks
Steve
Thanks
Steve
Posted Sat 30 Oct 10 @ 6:59 pm
Thanks
Steve
Thanks
Steve
Forgot to mention that im running vdj7 pro, basic Mac book and, rmx controller.
Posted Sat 30 Oct 10 @ 7:01 pm
Right click on browser and tick bpm
Posted Sat 30 Oct 10 @ 7:42 pm
I tried that and all it say's is "reload or set as alternative base folder"
Posted Sat 30 Oct 10 @ 10:40 pm
any other suggestions I'm thinking that the premium membership might be my only option at this point. I only got 8 hrs to go before party time.
I have 500 songs in my itunes library l rather use as long as i can get the bpm's
thanks
steve
thanks
steve
Posted Sun 31 Oct 10 @ 9:35 am
Since you have a Mac you need to ctrl click or if you have a mighty mouse you can right click on the external volume. So expand volumes and right click on the external drive. Then click add to search db. This will scan the entire drive for media files VirtualDJ can play.
Posted Sun 31 Oct 10 @ 10:07 am
Come to find out that I guess I accidentally reformated my external hd some how so I lost everything that was on it.
Posted Sun 31 Oct 10 @ 11:53 am
Please check your pm's
Posted Sun 31 Oct 10 @ 1:22 pm
Okay, don't panic. All your stuff is still there, you just can't see it. I accidently re-formatted a drive awhile back as well. It contained all my ACRONIS backup files for my computer.
I went to: http://data-recovery-software-review.toptenreviews.com/
I read up on every program there. I decided to get the Recover My Files program. I was able to get back every single file on the that 500 GB drive. Just don't write any more files to it. Any program on that list is good but i do now have personal expereince with the one mentioned. I downloaded the trials for the rest, but I liked that one best.
Good luck,
DGee
Good luck,
DGee
Posted Sun 31 Oct 10 @ 7:41 pm
