Hi to all,
I'm using the CIOCE's Rmx skin and mapper, but i've personalize a bit to fit me:
- I use the gain Slider on both decks to modulate active effects
- The track+ / - to have 2 more effects since i use
- 4 button to double loop
- 5 button to in/out loop
- 6 button to split half loop.
The question is if i can move the sliders on effects even if they are not active (like when you kill eq, you can still move the sliders...).
My point is after using an effect, put the levels back to what i need before using it again...
Is it possible?
Thanks in advance
DJ LUIS T
Is it possible?
Thanks in advance
DJ LUIS T
Posted Fri 29 Oct 10 @ 10:50 pm
