i'm running an HP laptop pavilion dv7, core i7 @1.60-2.8, 6 gb ddr3, Nvidia GT230M 1gb vram, 2 internal 500gb hard drives and windows 7 64bit.
i have owned numark cue and Virtual dj for a while now, it has worked fine on other computers and the program it self works life on this laptop. But i can not get the numark supplied sound card to function on here... it shows up in the device manager but says there is a problem with it. VV will not see it either. i tried downloading 64bit drivers for the sound card off numarks website but both of my windows 7 machines willl not get it to work. they both say this drivers are not digitally signed and will not function on windows. any help is greatly appreciated.
Posted Mon 25 Oct 10 @ 4:31 pm
i habe the same problem:(
only 32 bit suckz .
i write a mail to numark 14 days ago...but no response.
they sold hardware and make a lot of money, but the service from numark is bullshit.
many people has problems with VV 64 bit..the beta-driver is not working....so 64 bit is a very new system (hahaha after 4 years ?? )
i think numark will only make fast money, but service is a desert for this company.
next time i upgrate to VDJ PRO and the numark VV-Box goes recycled...and then no more numark.
greetz from Germany and hope my english is not too bad.
Thomas
only 32 bit suckz .
Thomas
Posted Mon 25 Oct 10 @ 7:30 pm
i figured out how to do it after my post.. you need to boot in safe mode and click some opinion for no certified drivers
Posted Tue 26 Oct 10 @ 2:03 am
i have a windows 7 64 and i also had the same problem. when you boot up your pc, tap f8 until you get a menu. Select the option that disables the digitally signed driver guard and let your pc boot up. Next run virtual dj/cue/vinyl and you may still get the no soundcard message. Then go to config and click on to the drop menu for the sound card. Virtual Vinyl should be an option.
Posted Fri 28 Jan 11 @ 9:21 am
