hi someone i no is selling there vestax cdx-05 (two of them) and i am thinking of buying them just wanted to know if i can map them to vdj and also what else i wood need to buy i use a rmx at the moment any help wood be greatful thanks
Posted Wed 20 Oct 10 @ 3:52 am
its not midi, so you would need to use TIMECODE cd (a special CD with a PC signal, that tells VDJ what you do on analogue CD player)
the Timecode CD is free here:
https://virtualdj.com/products/timecode/cd.html
You would also need to use your RMX inputs, and connect each CD player at line in of your RMX (or similar card)
Hope that helps ;)
Posted Wed 20 Oct 10 @ 4:42 am
thanks for the help
Posted Wed 20 Oct 10 @ 6:32 am
