VirtualDJ '9' is indeed a warez version.
The latest VirtualDJ is v7.0.2 and is available for free here:
https://virtualdj.com/download/free.html
Posted Sun 02 Jan 11 @ 4:50 pm
Not to thread jack but I do have a clock question also.
I am using Cue Rmx by Cioce version 2.2
The clock displays military time. . . is there anyway I can have it display civilian time?
Posted Sun 02 Jan 11 @ 5:56 pm
karaokekev wrote :
go into my documents and open the virtual dj folder, then click on the skins folder, look for virtual dj 7 (4decks) open that and drag aand drop the 1440 x 900 xml file to your desktop, right click on it and select open with and use notepad to open it, change the text listed (its worked on mine) then save the file, then simply just drag and drop it back into the skins zip file to replace the original copy
Thank you. I am a little slow, but your explanation, and a little thinking helped me pull this off. I still don't like the font, and will try to learn how to change that.
Posted Sun 02 Jan 11 @ 10:36 pm
CadDog wrote :
Because of my poor eyes here what I have done...
How did you do this??
Posted Sun 02 Jan 11 @ 10:43 pm
