Hi all,
After getting used to Virtual DJ 7 Pro, I came across my old Mixmeister Controller lurking in a cupboard, and thought that it would make a cheap 4 deck controller.
So anyway...been learning device mapping, controller mapping and VDJScript and have come up wiith a usuable mapping set.
Here's the first of a couple of vids showing it...
Video 1 is a talk-through of the features with video 2 being a little demo.
Two functions I did forget to explain are that the T5 and T6 buttons do the following:
T5 = Reverse
T6 = Beep.
Video 1
T5 = Reverse
T6 = Beep.
Video 1
Video 2
There's some odds and sods to finish off with the mapping and I might build a custom skin for it, so I haven't submitted the mapping - If any of the mods want the mapping/device files, let me know.
Oh and massive thanks to Supacon, who's original mapping on the Mixmeister controller saved me hours of trying to id the CC and NOTES of the controller (Numark's info doesn't include any LED notes and some of the controls are missing from their map).
and lastly, if anyone knows the NOTES of the leds for the following I'd appreciate the info:- cut/copy/paste/split/undo/select and pitch bend buttons.
Thanks
Simon
Posted Tue 19 Oct 10 @ 8:33 am
