Forum: Old versions
Topic: Numark mixdeck and VD7 problem recording
hello i hope someone can help me ive tried to record a set first, using vd6 and i think cuz its not a midi controlled mixer it only records the whole thing before entering a song and cues and loops that dont have to be incuided in the set and when i record it i can hear when im cueing it and vd7 same thing and now on VD7 i dont have the option to record from line in or mic or some other option it gave on VD6 PLEASE HELP ANY THOUGHTS OR IDEAS WILL BE GREATLY APPRETIATED! or a software just to record the set
Posted Mon 18 Oct 10 @ 12:35 pm
The mixer section on the mixdeck is not midi, just the decks. So either record to an outside source or u can use page up/page down to move your fader on the screen when you need to move it.
thnx, yes i know the mixer its not midi but if i go with an outside source what can i use to record on it? tried my ipod touches 4th gen and 2nd gen and it says its not supported tried my iphone 4 again it says its not supported so actualy im stuck =(
Well, u can invest in a cd or digital recorder. I have another laptop that I use to record by running rca jacks from record on my mixer to my mic jack w/ volume control on the scond laptop. You would need a program like nero, cool edit pro or anything else equivilent for recording. It sounds primitive but trust me it works. Sometimes you have to K.I.S.S.(Keep it simple stupid) LOL. But with my Hercules RMX I can record internally. I like flexibility....;)
I recorded a mix on my Mixdeck into my Ipod using VDJ6 and it works but sounds like crap..I also think it picks up the cueing on the other deck..sounds like something is scrapping..but low toned.I .wasnt happy with it..so I used rca out on the booth
and into my laptop mic /in and it sounds 100% better using on board soundcard.
Exactly Lineman, I just choose to use a 2nd laptop so that I don't have any lag or issues with latency.
thnx ill try using one of those programs and a second laptop but the mixdeck is a piece of sh*t i read the vd7 audio setting manual and actually u can rewire it by adding a record loopback but now it says i dont have enough channels and actually it gives me the option to choose a mixdeck line in sooo wtf????
thnx again for the tips yesterday i tried audacity pro but it sounds like sh*t jajaja!
having a problem with assigning 2 channels on my numark mixdeck. which causes a recording problem. when i play the first channel while im recording everything is fine, at the same time im listening the song on the second channel when the volume slider is down. but it still records the second channel. how do i fix it ? do i need to get a mapper for that ?
Read this thread,
https://virtualdj.com/forums/143125/Hardware_Technical_Support/How_To_Record_With_A_Mixdeck______.html
Hope that helps
Huey
Holla at me if you have problems
