I have VDJ mapped to swap between decks 2 and 4 using 'deck 2 rightdeck ? deck 4 rightdeck : deck 2 rightdeck' and it works great. I can see it is swapping when I press the button. However, it doesnt assign the timecode to the correct deck - timecode controls both deck 2 and 4 regardless of which deck is selected/active.
What I want is to have a track playing on deck 2. Press the button and it leaves track 2 playing without interruption, and gives me control over deck 4 using the time code so I can scratch deck 4 without affecting deck 2.
I thought this would have happened automatically as I cant see any reason to have two decks controlled by the same turntable at the same time?
Any ideas? Is there a separate command to turn off timecode on deck 2 and assign it to deck 4 maybe?
Posted Sat 16 Oct 10 @ 6:23 pm
Map two buttons, one with this "deck 1 timecode_active & deck 3 timecode_active & deck 1 timecode_active" the other with this "deck 2 timecode_active & deck 4 timecode_active & deck 2 timecode_active"
Huey
Huey
Posted Sat 16 Oct 10 @ 7:59 pm
