Hi their is their anyone that has the time and be able to break down how to map the hercules rmx in the simplest form / step by step?
example: I would like to be able to access all 12 samples with out going under the sample tab and an easier way to load them instead of going in to the sample tab and pushing the load and looking for it.
Also how to use the effects and sample when you get it from the down load plugin area.
and if their is any other tricks to mapping...
thanks steve
thanks steve
Posted Fri 15 Oct 10 @ 7:31 pm
in config under mappers i just followed the easy instructions and assigned 5 of the 6 buttons
here's my setup
1 is mixer pannel, 2 is video , 3 unassigned
4 is browser view , 5 is sampler , 6 is effects
nothin' real exotic
to use the effects ,after you download them dbl click and they will install themselves in the default user/documents/VDJ folder
and subfolder audio,video, transition
under effects tab look and see if its on the list
if you were running VDJ at the time of the install , just close it and relaunch
if you need more help just pm me
here's my setup
nothin' real exotic
Posted Fri 15 Oct 10 @ 11:57 pm
One key is to scroll through the effects
(Like this) effect select + 1
Another key will play the chosen effect
(Like this) effect active
Posted Sat 16 Oct 10 @ 7:44 am
