got couple minor issues,the volume meter lights don't display anything. in vrdj 6 i used the the cue to master monitor knob to control the master volume of virtual, now for some reason in vrdj 7 it reads that knob backwards.
thanks
thanks
Posted Fri 15 Oct 10 @ 7:23 am
just download the new mapper from plugins. the one for vci-300 mkii.
it has some differences from version 6.
Posted Fri 15 Oct 10 @ 2:09 pm
I have the VCI-300 (MK1) and the level meters work fine. Try resetting to factory settings (CONFIG -> Mappers, choose the VCI-300 then click icon at the bottom-left of the mappers dialogue box.)
The MONITOR SELECT knob has been inverted to match the labelling on the controller.
If you would prefer it the other way, change the mapping for MONITOR_SELECT to: param_invert & headphone_mix
Posted Fri 15 Oct 10 @ 5:13 pm
thanks the new mapper fixed that right up, any asio suggestions ? aiso 4all 2.9 works but does not sound that good, aiso 4all 2.10 sounds better i get complete drop outs (tried tons of different settings). Thanks for any suggestions. i am working with windows 7
Posted Sat 16 Oct 10 @ 3:39 am
