gear:
virtual dj 6.0.4
macbook pro new generation
umix 44 soundcard
2 cdj 800 mk2
behringer djx750
i recently purchased a u mix 44 to connect my decks to virtual dj. i am using the pro timecodes and playing them to the soundcard which shows it is recieving input, but when i am trying to configure the time codes on virtual dj it doesnt show it is recieving any signal.
my roomates older generation mac book pro works fine with it however.
any suggestions or solutions would be appreciated.
virtual dj 6.0.4
umix 44 soundcard
2 cdj 800 mk2
behringer djx750
Posted Thu 14 Oct 10 @ 6:47 pm
anyone have ideas?
Posted Tue 19 Oct 10 @ 4:46 pm
i before e , except after c , and 2 plus 2 equals 4.....
you should register your license and upgrade
6.0.4 is old , there's a new version , version 7 ..... if you are just waking from your coma .....
Posted Tue 19 Oct 10 @ 9:34 pm
pure3 wrote :
anyone have ideas?
you probably have too loud input, hence it looks like you arent receiving anything in the timecode settings.
Adjust the gain, until you see a circle
More on setting it up to work good here :
https://virtualdj.com/wiki/TimeCode%20Config.html
Posted Tue 19 Oct 10 @ 9:36 pm
