Hello,
I'm looking to get an answer to a couple questions and just want to make sure that the answers I found is truly correct.
I found this link - https://virtualdj.com/forums/133467/General_Discussion/VDJ_for_playback_only_.html?search=silence&page=1
And the post that takes a snippet from the VDJ 6 manual:
Playlist & Automix Management Using the Playlist management menu by clicking on the [+] icon and choose from the available options
for how the automix will function and tracks are managed in the playlist. Automix Types – 5 modes
• SMART – VirtualDJ attempts to determine the optimal mix point based on the outro of the current track and intro of the upcoming track – mix time varies from ~4 to ~8 secs depending on the tracks
• FADE (remove intro/outro) – attempts to remove the dead air intro or outro segments and creates a crossfade point based on the settings of the Automix Length
• FADE (remove silence) – keeps the entire track from beginning to end while removing any ‘dead air’ or ‘silence’ that may be present in the track and creates a crossfade point based on the settings of the Automix Length
• FADE (remove nothing) – keeps the entire track from beginning to end and creates a crossfade point based on the settings of the Automix Length
• NONE (back-to-back) – this is a simple CUT mix that plays the files from complete from start to finish including any air gaps at the beginning or end
Automix Length
Length used for the Automix FADE types. Lengths are 0 seconds (CUT), or 1, 2, 4, 8, or 16 seconds fades using the FULL crossfade.
Repeat
Two different ‘Repeat’ options are available. When clicking on the options button (‘+’) the ‘Repeat’ option lets you repeat the whole Automix Playlist. Once all tracks have been played, the Automix will start over again with the first track in the list.
Prior to or during the Automix, right click on a song and select ‘Repeat’ to have that song continuously repeat until the ‘Repeat’ is deselected.
Clear – clears the entire playlist of all tracks Shuffle – shuffles the contents of the playlist for play Remove played – removes any already played tracks from the playlist Remove duplicates – a removes any possible duplicates from the playlist
Save – provides function to save the playlist for future use. Saved playlists can be loaded from the Playlist option found on the left Navigation panel. Saved playlists are stored to the My Documents/VirtualDJ/Playlists folder
I just want to make absolutely sure that "FADE (remove silence)" truly removes any pre-track silence much like I was accustomed to with CD players. VDJ 7's demo isn't very friendly in the sense that I can't really get myself set-up completely (using USB mixer and MIDI controller) since I can't use a MIDI controller in the free Home edition and couldn't find a demo for the Pro edition.
Also, is Virtual DJ able to integrate USB mixers (I have a Rane MP4)? My MIDI controller, out of curiosity for those reading and seeing my mentioning of a controller is a Denon DN-HD2500.
Thanks for any help provided!
Automix Length
Repeat
Posted Wed 13 Oct 10 @ 3:05 pm
