I just downloaded and installed the upgrade - works flawlessly on my Windows 7 PC.
Just wanted to say that this is great work, guys. I've wanted multi deck mixing for a while now.
Am I crazy or are there some improvements to the sound engine?
My mixing sounds smoother and the sound is crisper - love it!!
Posted Tue 12 Oct 10 @ 7:36 pm
NEW AUDIO ENGINE
Because the quality of the sound is of paramount importance to any real DJ, VirtualDJ 7 makes sure to bring you the best sound science can make.
The new Advanced Master Tempo will give you a sound clearer than ever, even at extreme pitch changes.
While the new Pure Scratch mode will give you a high-fidelity scratch emulation, sounding more real than the real thing.
Posted Tue 12 Oct 10 @ 8:41 pm
thanx thanx ..
And yes.. improvements in audio engine too ..
for a "whats new" in vdj 7, look here
https://virtualdj.com/products/virtualdj/version7.html
definitely gonna ignore the girlfriend tonight.........AHAHHAHAHAH
Posted Tue 12 Oct 10 @ 8:49 pm
Yeah Nice!!
Posted Tue 12 Oct 10 @ 11:09 pm
First I have to say I am blown away buy this Version 7. Totally state of the art !
Yes, the Master Tempo Stretch is a vast improvment. And I have a request for a teenie weennie tweak.
When taking the song down to 0 BPM right now it shuts off the sound when you hit zero.
You are sooooo close to perfection. It would be ideal to be able to slow to zero RPM and when it hits zero... sound still plays. It's an awesome effect. Right now when you get down to low RPM a few RPM above zero... the sound aliases, and then at zero the sound shuts off.
I used to use OTSDJ before I started using VDJ, and when their platter is set to +-100... and you slow down in key... and stop at zero... it still plays the tone in the same key as the song. It's really cool, and you guys are really really close.
I would very much appreciate you looking into this enhancment request for a future release.
The effect as you have it is usable, and I will enjoy playing with it. The fun begins like never before.
I have to swing the other direction and say this Version 7 is the most magnificient DJ software ever built. I can't believe all the new stuff. It's all working perfect. I'm using 4 players. The creativity is flowing like never before.
I'm going with the Black Vestex VCI 100s if I can still buy them. I'll probably just use 2 of them controlling 4 decks.
Wow ! Atomix ... team ... You blow my socks off !!! I am totally amazed by Version 7.
Regards,
Jim L.
Regards,
Jim L.
Posted Wed 13 Oct 10 @ 2:09 am
I'm really glad the master tempo enhancement has been implemented to V7 - I'm a club DJ so good sound is a must.
I've always loved the way Traktor sounded but now with this fix I can't think of a single thing that would make me want to move to a different program.
The only thing wrong with V7 is that sometimes the wave forms dont show up when I sample off the 3rd or 4th deck - I'm sure that will be fixed at some point.
Again, great work guys.
Posted Wed 13 Oct 10 @ 5:32 pm
