how do i press a button n the hercules so it shifts from one deck to the other.......without using the keyboard?
Posted Tue 12 Oct 10 @ 5:53 pm
you mean like how would you get it to switch from decks 1&2 to decks 3&4? you would have to map something out, either on the keyboard or on the RMX itself, but I wouldn't have the foggiest idea on what the map code/codes would be honestly. Sorry I wasn't much help, lol.
Michael
Michael
Posted Tue 12 Oct 10 @ 6:15 pm
i have 4- 6 decks......and i am still using 2......how do i get to switch to the others and get ready to mix while the previous ones are running.
Posted Tue 12 Oct 10 @ 6:17 pm
tab switches from one deck to another deck on vdj 6
Posted Thu 14 Oct 10 @ 8:16 pm
i use the SOURCE code:
action_deck 1 ? deck 1 leftdeck ? deck 3 leftdeck : on & deck 1 leftdeck : deck 2 rightdeck ? deck 4 rightdeck : on & deck 2 rightdeck
it enables you to switch to deck 3 or 4, depending on which side of the source button you press.
i got it from this post
https://virtualdj.com/forums/135637/PC_Version_Technical_Support/RMX___VDJ7.html
Posted Thu 14 Oct 10 @ 8:57 pm
but that switches BOTH decks at same time ??
From being 1 & 2 .. to being 3 & 4 ..
For any controller that have 2 buttons mapped to same function (meaning it doesnt specify in the mapper if the button are left on the controller or right on the controller) like the SOURCE button on Hercules RMX (its just ONE source button in mapper settings, not two.. like Source_left and Source_right).. Having ONE in mapper is made to simplify mapping controllers..
But to have DIFFERENT actions on SAME button on both sides of the controller do this :
device_side left ? deck 1 leftdeck ? deck 3 select & deck 3 leftdeck : deck 1 select & deck 1 leftdeck : device_side right ? deck 2 rightdeck ? deck 4 select & deck 4 rightdeck : deck 2 select & deck 2 rightdeck
(for example at the SOURCE button at Hercules RMX)
This way you can change to deck 3 and deck 4 independently :) on right and left source button on the controller
The scripts "asks" if you press on the left side of the controller or right side :) and act independently
Adding SELECT to the script is useful, as it will also make this the dominant waveform (active), as well as headset prelisten (unless you are using PFL buttons manually in the skin)
Posted Thu 14 Oct 10 @ 9:48 pm
Now please give me the god code for the scratch button not having to be toggled!
Posted Fri 15 Oct 10 @ 4:21 am
Not sure I understand..
What do you want the scratch button to do?
deck 1 vinyl_mode & deck 2 vinyl_mode & deck 3 vinyl_mode & deck 4 vinyl_mode
This should turn on/off scratch for all 4 decks
Posted Fri 15 Oct 10 @ 5:24 am
And how about the script from 4-mx?
action_deck 1 ? down ? deck 3 leftdeck & deck 3 djc_shift : deck 1 leftdeck & deck 1 djc_shift : down ? deck 4 rightdeck & deck 4 djc_shift : deck 2 rightdeck & deck 2 djc_shift
This will be ok on the SOURCE button of the RMX?
One important thing is the led on on switching from 1/3 or 2/4.
Is it possible?
Is it possible?
Posted Wed 10 Nov 10 @ 2:10 pm
Take a look at https://virtualdj.com/wiki/VDJScript%20Examples.html
The second example will allow you to toggle decks with the button LED (If it has one) showing which is selected.
NOTE: Not all buttons on the RMX have LED backlights.
Posted Wed 10 Nov 10 @ 3:16 pm
Not shure i understand...
What should i add on the code
So the led is on when sellect 3 and 4 decks?
Posted Wed 10 Nov 10 @ 4:13 pm
Ok so I'm ready to buy Hercules RMX; However, I am confused on two things. I bought Newmark CUE... Will the Hercules RMX still work with it? Or do I have to use the version of VirtualDJ that comes with it? And another thing, is Newmark CUE the same as VirtualDJ Pro 7?
Posted Wed 10 Nov 10 @ 10:41 pm
SHIFT on the 4-Mx is a toggle button that toggles the 6+6 buttons between buttons 1-6 and 7-12.
Assuming that is the same on the RMX, you could try the following:
action_deck 1 ? down ? on & deck 3 leftdeck & deck 3 djc_shift : deck 1 leftdeck & deck 1 djc_shift : down ? on & deck 4 rightdeck & deck 4 djc_shift : deck 2 rightdeck & deck 2 djc_shift
Posted Thu 11 Nov 10 @ 12:41 pm
the real deal...https://virtualdj.com/wiki/VDJScript%20Examples.html
Posted Thu 11 Nov 10 @ 9:08 pm
Hi there,sorry being stupid, where, how do I add the code, thank you
Posted Fri 13 Jul 12 @ 4:30 am
You need Virtual DJ Pro to be able to add custom mapping.
Keith
Keith
Posted Fri 13 Jul 12 @ 5:13 am
Most of the time when a script question is asked on the forum everyone points to the "script wiki"....A lot of good info there, but it in itself is extremely confusing to ppl. that are not comfortable writing what is essential basic computer code. Most of us realize the wiki is there, but we cannot string commands together and make them work properly many times.......Just food for thought.....
Posted Fri 13 Jul 12 @ 7:05 pm
