Hi DjDad
First of all thank´s for your great work. I love this skin.
But I did something wrong. I tryed to map the Browser Zoom funktion with \"aktion-learn\" on a button of my RMX. After this my screen shows:
file:///https://virtualdj.com/image/thumb/94548/85321/Skin.png.
I tried to delete the skin and installed it again. Same screen.
This is only in my resolution of 1366x768. If I take another resolution the screen is ok.
Have you any idea how to correct this?
Many thank´s
dieter1803
Many thank´s
dieter1803
Posted Wed 14 Mar 12 @ 4:26 pm
Remove the skin (zip file) from MyDocuments\Virtualdj\Skins folder and download /install the skin again.
I cant tell what went wrong there for you.
What is the action you used for that controller button ?
Posted Wed 14 Mar 12 @ 6:57 pm
Thank´s for your quick answer.
I removed, downloaded and installed it four times!!!
For the mapping I didn´t use a writen aktion. I tried it with the aktion learn button in the mapper.
Posted Thu 15 Mar 12 @ 2:38 pm
I see now. The button that switches the views has multiple actions, depending what mode you have ...
Try this ..
skin_panel 'decks' on ? skin_panel 'fab' on ? skin_panel 'z4ab' on & skin_panel 'br4' on : skin_panel 'fsb' on ? skin_panel 'z4sb' on & skin_panel 'br4' on : skin_panel 'tab' on ? skin_panel 'z2ab' on & skin_panel 'br2' on : skin_panel 'tsb' on ? skin_panel 'z2sb' on & skin_panel 'br2' on
This switches to browser mode properly, depending the mode you are..
I cant find an easy one to toggle back, but i will let you know soon..
Try this ..
Posted Thu 15 Mar 12 @ 3:35 pm
Wow, great.
I use this and the normal skin arrives.
If its also possible to toggle back i´m in heaven.
Many thank´s
Many thank´s
Posted Thu 15 Mar 12 @ 3:53 pm
Ok, replace the action i gave you with this one
skin_panel 'fab' on ? skin_panel 'z4ab' on & skin_panel 'br4' on : skin_panel 'fsb' on ? skin_panel 'z4sb' on & skin_panel 'br4' on : skin_panel 'tab' on ? skin_panel 'z2ab' on & skin_panel 'br2' on : skin_panel 'tsb' on ? skin_panel 'z2sb' on & skin_panel 'br2' on : skin_panel 'z4ab' on ? skin_panel 'fab' on & skin_panel 'decks' on : skin_panel 'z4sb' on ? skin_panel 'fsb' on & skin_panel 'decks' on : skin_panel 'z2ab' on ? skin_panel 'tab' on & skin_panel 'decks' on : skin_panel 'z2sb' on ? skin_panel 'tsb' on & skin_panel 'decks' on
That will toggle back and forth properly now.
Posted Thu 15 Mar 12 @ 11:14 pm
The new waveform options in this skin (Option 1) is something i've been waiting on for ages but didn't know how to implement it. Great Work!!
Posted Fri 16 Mar 12 @ 6:37 am
Hi DjDad
Today I had time to test the new action.
It works great. Thank you very much for your excellent work.
Posted Tue 20 Mar 12 @ 8:54 am
