I have issues trying to get the right timecode setup to work. Tracks are jumping around when I hit play, when I hit stop the track automatically starts playing backwards or jumps to the end. Can't use the restart cue button on my CDj, all that happens is the song just stops or jumps.
I just upgraded and regret it because I understood what I had before with VDJ 5. Ofcoarse there is never any support with the mix vibes folks, so I hope someone out there has already figured this out.
CDJ 1000's
CJM 600 mixer
U46MK2 soundcard
CDJ 1000's
CJM 600 mixer
U46MK2 soundcard
Posted Sun 10 Oct 10 @ 6:57 pm
Ok so I can use the VDJ cd for my timecode and active relative, but every other song, the connection with my CDJ's is lost and I have to click apply for my CDJ's to be used again. Can there be a connectivity issue with my soundcard and VDJ 6 where the two are not talking. Mixvibes came out with a new driver for the U46 but it's still doing the same thing. Come on guys/gals I want to continue with VDJ but everytime there's a new update, I wait atleast 6 months before making the move and now VDJ 7 is out so not sure what route to take.
Posted Wed 13 Oct 10 @ 8:12 pm
What are the secrets behind the timecode configuration that I'm missing? Before, I would only have to click on timecode config and it would automatically set itself up and things were great but now I have options but the only configuration I see that works is virtual dj but even that doesn't work half the time. I was mixing at home for 3 hours straight and I had to click on "apply" in the sound configuration page every other song because VDJ would not respond to my CDJ's controls. I'm ready to spend $150 to get the mixvibes cross program because I just don't see VDJ and the U46MK2 working correctly anymore. Unless I'm missing something in my setups, maybe a latency issue? I am going to disconnect everything and reconnect, I wonder if I revert back to an earlier configuration in my laptop, will VDJ 5 still be available?
Posted Thu 14 Oct 10 @ 12:54 pm
It seems like I'm writing to myself. VDJ PRO's can anyone shed some light on this? I haven't found anyone else with a similar problem, here's what's funny. VDJ works fine, the pitch bend doesn't respond as well but I just hit SYNC and don't really worry about adjusting the pitch on my CDJ. But after about 3 songs I have to click APPLY on the sound setup page as stated before. I get a click sound where the music skips but I manage to not make it obvious with my effects on the mixer. This is really annoying as I have to add yet another step into just mixing without doing any tricks. For this I can just use my laptop and not even worry about my cdj's if I have to continue.
I seen a demo on the new mixvibes program and the cue buttons on the CDJ work. I might just have to sell out and go mixvibes if I want to use my CDJ's. I've asked to get an older version of VDJ as a last resort and then after that I'm done with VDJ on this setup unless someone figures this out.
Posted Thu 11 Nov 10 @ 8:04 pm
