as i read in a few topics, the sound card Deejay Trim by Hercules is only compatible with MAC OS X 10.4 and MAX OS X 10.5 so which sound card should i choose to use Virtual Dj with a macbook with MAC OS X 10.6 and which works for real and which was tested by another member?...
thanks a lot
thanks a lot
Posted Sun 10 Oct 10 @ 4:19 pm
no it is not the only soundcard that can be used.most souncards come or can download mac drivers to use.
i use my mac with numark djio soundcard as backup also used this with my windows when i started using vdj a couple years ago and still working grand
Posted Mon 11 Oct 10 @ 1:20 pm
I own, have used and recommended to others, the excellent Edirol FA-66. It's a perfect companion for Mac and Virtual DJ.
Posted Tue 12 Oct 10 @ 8:23 am
