hi there guys has eny one figured how to control the effects buttons on the dns3700 with vdj7pro or how to change them most buttons are ok but effects?????
Posted Thu 14 Oct 10 @ 8:11 am
HEY GUYS HOW DO I GET VDJ 7.0 TO RUN ON 4 DECKS
Posted Thu 14 Oct 10 @ 7:03 pm
Read the manual yet?
Posted Thu 14 Oct 10 @ 7:08 pm
The effects buttons by default are mapped already. You can however go in and customize the mappings by changing the verbs/actions.
Posted Thu 14 Oct 10 @ 7:10 pm
yes i got it but cant get 2 of them to play
Posted Thu 14 Oct 10 @ 8:05 pm
gbeul wrote :
@denon-dj
hi ihave updated now one player and it could not connect in midi restarting the hole things vdj an 3700 bring no efect player is recocniced as simple midi config xml in plase or not no diffrenz setup is win7ultimate 64 vdj7 one dn-s3700 with new firmware (at the moment)please addvice
thanks dj-agua
thanks dj-agua
please anybody here that can help????????????????
Posted Fri 15 Oct 10 @ 3:22 pm
wats up with the new 3700 update 2010
its messing me up my 2 players are on deck 1 so if i press play on one the 2 of them spin be4 on the players it use to say 1 and 2
Posted Wed 27 Oct 10 @ 8:40 pm
did any one install the new denon 3700 update (firmeware 2010) came out oct 26 2010
Posted Thu 28 Oct 10 @ 2:33 pm
Works fine for me and others.
Posted Sat 30 Oct 10 @ 8:27 am
OK ITS ALL GOOD NOW JUST HAD TO RESET VDJ THANKS
Posted Sun 31 Oct 10 @ 5:12 am
