HELP!!!
I am using a Vestax VCI-100, with VDJ Pro, & an iMIC ext card. I cant seem to be able to monitor the tracks in the headphones! I can either have a monitor, or a main out, but not both. What am I doing wrong??
HELP!!!!
HELP!!!!
Posted Tue 05 Oct 10 @ 10:36 pm
iMIC is not a multi-channel sound card. You'll have to use it in conjunction with another sound card. Then you'll go to configuration and select
Inputs: None
Outputs: Headphones
Soundcard: 2 Cards
and then on the two drop down menus on the right you'll pick iMIC as your first card and the internal soundcard of your laptop as your second.
Inputs: None
Outputs: Headphones
Soundcard: 2 Cards
Posted Wed 06 Oct 10 @ 12:39 am
