Ive got a hercules steel and with it i got vdj djc edition but ive moved house and ive lost the disc! ive downloaded the drivers and using the hercules in fl studio, but where oh where can i download a vdj djc edition so i can once again use the steel with vdj. im missing it! also is there a pro version where i can map the steel into it ?
Posted Sun 03 Oct 10 @ 11:05 am
Should be able to download here: https://virtualdj.com/download/updates.html
Pro version available to buy here: https://virtualdj.com/buy/ - make sure you enter you DJC version serial number at the bottom- pretty sure you'll get a discount.
You will be able to custom map in the pro version.
Posted Sun 03 Oct 10 @ 11:08 am
ah brilliant thanks alot for the link man 1 problem tho. as ive lost the cd ive lost my serial! help!?
Posted Sun 03 Oct 10 @ 11:16 am
soz. found it.
cheers dan
cheers dan
Posted Sun 03 Oct 10 @ 11:17 am
Glad your sorted.
Posted Sun 03 Oct 10 @ 12:28 pm
