Still doing the trail and still loving VDJ6.
I have the DMC2 and i want to use the Selector knob as the effect slider.
I still want to use the other things the knob does. Browse effet activate and so on.
I had a thought that if i press the FX/Sampler button to select FX and when the FX is active i should press FX/Sampler again and the FX led should flash and the selector knob is now the effect slider. Can this be done?
Posted Fri 01 Oct 10 @ 4:31 pm
Yes, that's definately possible, although it's easier to map the jog wheel to be the effect slider. I have it set up so that it switches automatically whenever the effect is active.
It's a bit more tricky with the selector knob because there's actually 2 maps for it, one when you turn it clockwise and one where you turn it the other way.
Posted Sun 03 Oct 10 @ 5:12 am
I managed to get the selector knob as the effect slider, both ways. But i lost all the other functions
Posted Sun 03 Oct 10 @ 5:37 am
Copy it's original code and then type:
effect active ? effect slider : <<<<the code you copied>>>>
Posted Mon 04 Oct 10 @ 2:17 am
