hey folks..i have a problem that i am sure is easy to fix..today this happened to me..
I was mixing etc then by accident i cued up the next song..in the channel of the song that was playing..grrrrr..is there a lock or warning popup so i dont do this again?...pretty embarrasing stuff..imagine a song playing..then...cut...grrrrrr
Posted Thu 30 Sep 10 @ 5:49 pm
Yes, this is your warning, don't do it again.
Posted Thu 30 Sep 10 @ 6:03 pm
Check the pic,
make sure its set to "ASK" or "ALWAYS"
Hope that helps
Huey
Hope that helps
Huey
Posted Thu 30 Sep 10 @ 6:10 pm
Yes under Config in VDJ I think its in Options, make Security to ALWAYS or ASK and it will either ask you if you are sure or will load to opposite deck.
Posted Thu 30 Sep 10 @ 6:11 pm
Beat me to it by 1 second.....
I saw that, lol!!
Posted Thu 30 Sep 10 @ 6:13 pm
How do i unlock it i cant press any thing!!Pls Helppp!
Posted Sun 16 Jan 11 @ 9:27 am
@ deepkesh14...you will find, as a non-licenced user that there are many things in the config that are not available to you. If you want to explore the full potential of Virtual DJ then a PRO licence is the way to go...a whole world of possibilities will open for you.
https://virtualdj.com/buy/
Posted Mon 17 Jan 11 @ 6:16 am
