I'm trying to quickly (and easily) set up my APC40 to use with VDJ. Using the simple midi wrapper under the config screen, is it possible to set a fader to deck 1 and another fader to deck 2. At the moment it only seems to set it to control whichever deck is in focus.
EDIT: Ignore me. I'm a tit...have sorted the problem, thanks.
Posted Fri 24 Sep 10 @ 10:28 am
