Is there a way to get ride of the doubles that i have. when i look up a song it shows 2 or more of the same song for some.
Posted Thu 09 Sep 10 @ 3:52 pm
I wanna know that oo because when I delete them they don't delete.
Posted Thu 09 Sep 10 @ 3:53 pm
try right click and remove from search database
Posted Thu 09 Sep 10 @ 11:07 pm
I know there was a thread on this a while back but i think someone said there was a program that would do this, delete doubles. Not sure though. I would say just google it and see what you guys can come up with and don't forget to let us know what you find or use, lol! Might help others.
Huey
Huey
Posted Fri 10 Sep 10 @ 12:11 am
Hello,
I've recently bought my DJ Console RMX, which i was using with my last laptop till i got a virus.
I have lost my virtual dj console 5 djc edition cd, since without the cd, you cannot use the consolel.
If anybody can tell me where i can find to download or buy the cd which can install the softwar muce on the new laptop.
xx peace & light xx
xx peace & light xx
Posted Fri 10 Sep 10 @ 4:41 am
contact hercules, it would be better if you had opened a new thread on your problem next time though.
Posted Fri 10 Sep 10 @ 5:05 am
try this http://www.mixshare.com/wiki/doku.php?id=rapid_evolution
deepstuff .....don't hijack
download the drivers from hercules 2010 HDJS_2.exe
use the demo
buy the pro ......
use the demo
buy the pro ......
Posted Fri 10 Sep 10 @ 4:16 pm
The manual way is if you search on your folders (windows key + F) for all files, then sort by filename and it will group similar filenames together just delete until you only have one of each. Im sure there is a program out there to do this quicker but I dont know it
Posted Sat 11 Sep 10 @ 5:36 am
