Hello Guys,
i am mapping my beringer ddm4000 mixer with VDJ 6, and i can do most basic ones with no probs... however i got stock with the active deck behaviour.....
for some reason i have to toggle between the PFL "active deck" so the the mapping works for that specific deck,
example i mapped a button on the left of the mixer to sync deck a and a button on the right of the mixer to sync deck b. but if the active deck is on the right i can press the button on the left and it will highlight the sync button on the right... I DONT WANT TO TOGGLE BACK AND FORTH... it can be horrible when mixing in my gigs...
i dont have this issue with any of my other equipment like my CDJ's...
Q1. can i map deck specific, for example "sync button deck a"
Q2. can i set it up so if i assign a button in my mixer, when pressed will work regardless of which one is the active deck
thanks!!!!
thanks!!!!
Posted Tue 07 Sep 10 @ 2:52 pm
Use the 'deck #' action command, like: deck 1 sync
Posted Tue 07 Sep 10 @ 2:55 pm
im trying that tonight... pretty ez fix.
thanks
thanks
Posted Tue 07 Sep 10 @ 2:58 pm
