Topic: Help with hooking up Virtual DJ
Hey guys. I'm new here. I need a little help hooking up my pair of CDJ-200's with my mixer to my PC and of course Virtual DJ software. I'm running Windows Vista and I recently bought a Tascam US-122 Audio/MIDI Interface to make a connection between my computer and the rest. How exactly should I hook it up so I can play on my CDJ's using Virtual DJ??? Any help greatly appreciated.
Posted Mon 23 Aug 10 @ 7:16 pm
how recent did you get everything
return the Tascam and buy something like the hercules RMX ,
if you just bought the cdj200s I would return those also can get something like the CDJ 400 with the cd400 you won't need the RMX
it has built in sound cards...(just need a regular mixer)
See other compatible Hardware here..
https://virtualdj.com/products/hardware.html
Thanks for advice haz0rd. I've bought the whole setup form one of my friends. I've got a really good deal on it. I actually thought about getting rid of CDJ's 200's and getting a newer pair. I checked that Hercules Console. It is not very expensive and it would definetly help me out with my current set-up.
