I have an hercules controller but it didn't come with a vinyl disc and i don't know if there's any other disc that i can use to control my virtual dj using the 4 in and 4 out sound card.
Posted Mon 23 Aug 10 @ 2:54 am
Hercules DJ Console Edition does not come with timecode CD's - It comes with a free limited DJ Console Edition that can be used with the DJ Console Only. The DJ Console Edition does not support timecode, any other controllers or stand-alone use.
If you wish to use timecode CD or vinyl, then you will need to upgrade to VirtualDJ Professional: https://virtualdj.com/buy/ - If you enter your DJ Console Edition serial number in the box provided, you will receive a discount.
Timecode CD's can be created yourself using the file that can be downloaded from https://virtualdj.com/products/timecode/cd.html
Posted Mon 23 Aug 10 @ 5:13 am
