Is there any possible way to sync VDJ with an external mixer?
What I'm trying to achieve is this...
I use turntables, CDJs and mixer as any club set up, but would like to know if while playing on these,
I could sync them with a track being played in VDJ, so I could mix between vinyl, cds and mp3 simultaneously
using a lead going from my mixer into my pc line-in (which I already have connected).
I can mix this way, but the BPM/Tempo is never spot on.
Is there a way VDJ could "listen" to the mixer and beat-match within the program itself?
I know you can't see any recording levels in VDJ so probably, this may not be the case.
If VDJ was able to record directly from line-in (from mixer) just in the same way Adobe Audition and Audacity do,
and to see the sound/recording levels and visually beat-match tracks, I think that would work.
Maybe a future feature for VDJ - Support for external recording enabling internal and external beat-matching simultaneously.
Thanks for any info.
Posted Fri 20 Aug 10 @ 1:18 pm
We (myself and other DJ's I work with) often use iPhones/iPads, CDJ's, Nintendo DS' VDJ, etc, etc at the same time, running through a mixer and I'm afraid it's simply back to good old beatmatching by ear...
Posted Mon 23 Aug 10 @ 10:57 am
Always been the same, in the old day's it was record's, CD's and mini disc's
Generally, you had music scattered across a few sources and had to mix accordingly.
Posted Mon 23 Aug 10 @ 12:17 pm
Practice makes perfect...
on another note.. I am not sure if VDJ Supports Midi Clock or not
but if your mixer supports midi clock and has a BPM Couter, you may be able to send the BMP Signal
back and forth to vdj..
This is what I do sometimes.
I tap the beat out on my mixer.
I use the number to get me close to where I need to be
fine tune the pitch by ear.
Posted Mon 23 Aug 10 @ 8:31 pm
