I want to remove either all my music and reinstall it into the VDJ or remove the software and do a clean start with it. I tried to remove VDJ but when I reinstalled it, it had music files I want removed. It seems when I delete them while in VDJ they are still there.
I have dead music files that give me an error when I put them on the platter but I can go to iTunes, pick it out & drop it right into VDJ. When I go back to look for them they are nowhere to be found or the same dead file is there.
Posted Thu 19 Aug 10 @ 12:30 pm
If you delete or move files outside of VitualDJ then it has no way of knowing this and the files will give you an error when you try to load them (The database entry for the file now points to a file that no-longer exists.)
To correct, go to CONFIG -> Browser, choose the appropriate drive and click on CHECK
To add music to the database (E.g: In its new location), browse to the appropriate drives/folders, right-click on them and choose Add to search DB.
Posted Thu 19 Aug 10 @ 2:16 pm
Hi i am very new in this game so i want help from the VirtualDJ community 1}to know more about DJs 2]to know how to set this program in my computer
Posted Fri 20 Aug 10 @ 6:07 am
@Dj Ace:
If you DON'T mind loosing all your cues, BPM's, e.t.c. then:
1) Uninstal VDJ
2) Go to your "My Documents" folder and delete the "VirtualDj" folder if it still exists.
3) Open all your hard drives that you have songs on them. On the root of each drive you should see a file named "VirtualDj Database 6.xml" Delete these files.
4) Re-install VDJ
Now you should have a 100% clean installation.
1) Uninstal VDJ
4) Re-install VDJ
Posted Fri 20 Aug 10 @ 6:54 am
@ donchrist please feel free to start your own thread for your questions
this topic is on a specific database question and you had a question , not an answer
we call that hijacking a thread ....
we will help you , just please start your own topic ....
Posted Fri 20 Aug 10 @ 7:05 am
