The most common cause of this error is installing the software while logged in as one user (E.g: Fred) and then trying to run it as a different user (E.g: Joe.)
The other user is missing the My Documents\VirtualDJ folder. The program will not run without this.
To resolve, please either:
(1) Install the software as the user you will be running it as.
(2) Manually copy the My Documents\VirtualDJ folder across to the other user.
Posted Wed 25 Aug 10 @ 11:55 am
Hello,
I have the ‘DJ Control MP3 e2’ console by “Hercules”. My original software was the ‘DJ3 DJC Edition’ which was included in the package. All worked perfectly, no problems.
I bought the new software: ‘Virtual DJ Basic V6.1.2’, now the program only works via computer (Laptop), there is no connection between my console and the software.
When I start to use the old (original) program, everything works without any troubles.
For your information I have: Windows 7, Intel i7 processor, and all the latest drivers from “Hercules”.
How shall I fix this problem?
Thanks for your help.
Posted Wed 25 Aug 10 @ 10:20 pm
The Basic version does not support controller use.
"Designed for smaller venues, VirtualDJ Basic caters to DJ's who mix with a mouse and keyboard; " - https://virtualdj.com/products/basic.html
And from the Comparison chart - https://virtualdj.com/products/comparison.html
Posted Wed 25 Aug 10 @ 10:27 pm
Hi,
I wanna Thank Virtual dj For a Great Software Program
I am a Very Heavy User. I Use It 4 times a week when Do my Video Gigs
But 6.1.2 Crashed On Me once every night since I had it for last 2 weeks!
I Got NS7 with Hp dual Processors inside. This Never happen Before!
I am Planning to erase My Laptop and put a fresh copy Of 6.1.1
back on my P.C
Once I Use My Effects and Videos a few times.... It Locks Up and Nothing
works. Makes me Look bad..
Help!
back on my P.C
Help!
Posted Fri 27 Aug 10 @ 8:36 pm
Maybe you could post the contents of the crashguard files on here (they should be in your my documents/virtual dj folder on your computer) so that the developers can see what caused the crashes.
Posted Sat 28 Aug 10 @ 10:41 am
is there a date for vdj 7 release?
Posted Sun 29 Aug 10 @ 9:21 pm
Ya its just not posted anywhere :P Kidding.. no there is no date set. It will be out when its ready :)
Posted Sun 29 Aug 10 @ 9:52 pm
haha thanks
Posted Sun 29 Aug 10 @ 9:55 pm
I just installed virtual dj 6.1.2 and i'm using the Numark Ns7. I noticed when ever I move the picth control on the ns7 or the computer, I get a sound proplem. How can I resolve this problem.
Posted Mon 30 Aug 10 @ 11:52 am
i have vdj 6 its pretty good,and i doing sick mixes..
who wanna my mix to hear can add me on MSN (******************)
Sorry emails from No License Users is not permitted. Moderator
Posted Mon 30 Aug 10 @ 5:11 pm
^ just post it on the mixes thread man
Posted Tue 31 Aug 10 @ 1:21 pm
i just got a mixdeck and cant get it 2 work i did:
[PC]
Numark USB Audio Device v2.8.40 drivers
Leave the drivers on their default values.
MixDeck Unit Setup
Both Decks Source - USB-MIDI
Channel Source switches set to the center position - PC
VirtualDJ Soundcard Setup
Inputs - None
Outputs - External Mixer
Output Drop-down - Left deck: Chan 1&2 / Right deck: Chan 3&4
Soundcard - ASIO
Soundcard Drop-down - MixDeck ASIO Driver
Ultra-Latency - Checked
it says its connected the mapper says its on "mixdeck" but buttons do nothing!!!!!!!!!!!!!!!!
please help!
[PC]
MixDeck Unit Setup
Inputs - None
Soundcard - ASIO
please help!
Posted Wed 01 Sep 10 @ 1:15 am
Anything new on the basic program which we should know about..
I gave up on controllers years ago when I had one go bad in the middle of my gig.
I was able to quickly change over to the keyboard but
I heart didn't stop pounding until way later...
From that night on I started learning to work right off the keyboard...
This is one of the reasons I went with VDJ...
I'm able to program the keys to do anything I like doing...
Anyway, let us know it there is any other reason we should upgrade...
Thanks...
I love my VDJ, It Rocks... [2] Rocks, Rocks, Rocks, [2]...
Thanks...
Posted Thu 02 Sep 10 @ 10:32 am
Well the features are the main reason, the history is below.
https://virtualdj.com/wiki/VirtualDJ_History.html
Posted Thu 02 Sep 10 @ 2:10 pm
Wow...
What is really cool...
They tell you everything...
Thanks I didn't know this was around...
Very Cool...
Posted Thu 02 Sep 10 @ 5:18 pm
I notice that sometimes the VDJ pro, pauses for a long time, I thought it was the glich of windows Xp or just (Windows?) cant fix help the freezes and as you said on page 1 that some denon contollers interfere with the program or is that what the V6 .1 .2 for?
Posted Thu 02 Sep 10 @ 7:39 pm
we can probably help you , but we need more info
please start your own thread , so that we don't hijack this one
Posted Sun 05 Sep 10 @ 8:13 am
I can't upgrade. It asks me if I would like to upgrade, I say yes and install but it still asks me if I want to upgrade.
Posted Tue 07 Sep 10 @ 5:52 pm
If you are running Mac and moved the application to the desktop or to your Dock area - then you are not running the installed update.
Run VirtualDJ, look at the info tab - if it is not 6.1.2 then you are not running what was installed.
Go to your Applications folder and run the VirtualDJ application that is there.
Posted Tue 07 Sep 10 @ 6:45 pm
My first gig with 6.1.2 last friday:
no issues at all, seems more stable than 6.0.5
All went smooth for 9 hours straight:
Automix (4 hrs), then my set (4 hrs) with mp3, m4a, videos (vob; VGA-output to plasma), samples, video plugins, using the Hercules MP3 DJ control and the midi on my Ecler Evo5.
Thumbs up yet again.
And yes, of course, can't wait for a 3rd deck in VDJ version 7 ... !
Best,
Arie
Best,
Arie
Posted Mon 20 Sep 10 @ 8:13 am
