what is the difference between Mixtrack and Mixtrack Pro?
Posted Fri 18 Mar 11 @ 1:58 am
The MixTrack Pro has a built-in DJ sound card, allowing you to headphone pre-listen.
MixTrack has no sound card (May be a good option if you already have suitable sound card(s), e.g: Numark DJIO.)
Posted Fri 18 Mar 11 @ 9:09 am
what is the difference between the mixtrack and the mixtrack pro??????
Posted Mon 22 Aug 11 @ 10:16 am
Please see the post directly above yours.
Posted Mon 22 Aug 11 @ 11:10 am
do people not bother to research products these days of read the forums?
Posted Mon 22 Aug 11 @ 3:07 pm
HELP!! I just purchased a Mixtrack and having some cue issues. I use the mixtrack pro to do a livestream but been hearing my cue mix in my stream. I am using the same laptop that my VDJ and My Mixtrack pro is installed on to stream. Can someone tell me the correct settings? I have tried every possible setting with no luck.
Thanks
Thanks
Posted Mon 22 Aug 11 @ 5:05 pm
Posted Tue 23 Aug 11 @ 5:34 am
>Numark,
I don't know if this is only with my mixtrack or with the whole range, but when I'm fading out the eq's when mixing, there's always a click sound that comes through my monitors from when the EQ controlers are moved out of their set position at the top. Cause other than that, the product is awesome, I really like it.
Any help would be awesome.
Thanks, Jack.
Thanks, Jack.
Posted Mon 24 Oct 11 @ 9:52 am
