hi i bought a new computer, w7 64 bit (I could not find a 32 bit) , installed the drivers for djio 64 bit, use the same sound configuration as i used before (vista 32 bit), but know the sound is F horrible, i mean really really bad... am i doing something wrong?..
Posted Sun 08 Aug 10 @ 9:05 pm
click config
sound setup
outputs 2 channel mixer
soundcard ASIO DRIVER
in the dropdown box should say DJIO
check the box for ultra latency
sound setup
Posted Mon 09 Aug 10 @ 10:15 am
