Is there anyway I can install both 5.02 & 6.1 on my laptop, have the ICONS for both so I can run either version? I want to install (2) different versions of VDJ on the same computer & be able to access either..Thanx
Posted Tue 03 Aug 10 @ 10:33 am
It is possible - but remember that v6 has it's own database. So you have to edit all things doubble.
Posted Tue 03 Aug 10 @ 10:42 am
Ok Thanx, I understand about the databases. Could you tell me how I could install both versions & have BOTH ICONS ON MY DESKTOP?
Posted Tue 03 Aug 10 @ 7:11 pm
Posted Tue 03 Aug 10 @ 7:14 pm
I'm not sure this will work, but have you tried to re-name the install file, or change the location of it?
Posted Tue 03 Aug 10 @ 10:51 pm
uuuuuuuuhhhhhhhhhhhh place both shortcuts on desktop
rename one 5.2 rename the other 6.1
send me a blank check , thanx
Posted Fri 06 Aug 10 @ 11:37 am
The Icons on the desktop are just links - rename them as you like or make new ones direct from the programm folders.
Greets, Heiko
Greets, Heiko
Posted Fri 06 Aug 10 @ 12:44 pm
