Hello fellow DJ's
I have a problem that the sound level is very low from my CUE LE. (5.2.1) If i play mp3's from Winamp the sound level is much higher. I also tried whit VDJ 5 but it was the same result low output. I have a Sweex 5.1 soundcard, not the best but it does the job. Should i try to buy another soundcard?
Posted Tue 03 Aug 10 @ 1:26 am
If you have turned the master gain to max in the software you may want to look at a more powerful soundcard.
Posted Tue 03 Aug 10 @ 12:29 pm
Thanks for the answer it was as i suspected. Well let the hunt begin for a new soundcard.
Posted Wed 04 Aug 10 @ 3:19 am
