I'm looking at buying a wireless mic system but looking for a wireless mic system without the ugly antennas. I've used a couple cheaps sets over the years and the thing that keeps breaking is the flimsy antennas.
I'm not looking at spending a fortune on them. Shure looks too expensive from a quick look. I don't I'll get anyone singing on them lol..
Any ideas? Brands to stay away from?
Posted Fri 30 Jul 10 @ 1:50 am
Mine has antennas on the receiver however if you take them off I still receive a signal.
Posted Fri 30 Jul 10 @ 2:22 am
I have the Shure system and its worth the money imo.
Also normally use without the antennas and got into a bad habit of leaving them in the studio at home.
Then I got to an outdoor event with a keynote speaker quite a distance from the receiver, and all of a sudden I had drop outs...oops, now what.
Well I found a large paper clip in the booth and bent it straight, and it saved the day!
I was sweatin' it for a while there though.
Posted Fri 30 Jul 10 @ 4:50 am
The Sennheiser systems are expensive but the antennas are solid and detachable. I have used my one for years and the antennae can be folded flat behind the receiver unit.
Posted Fri 30 Jul 10 @ 4:59 am
Agreed, my Shure PGX system has a very short rubbery type antenna that, while it does not detach, can be folded in a variety of directions and I have yet to loose signal.
Posted Fri 30 Jul 10 @ 7:21 am
Bloody hell be careful with Sennheiser wireless mics as there made in China, I bought one and within 5 mins the button bust.
Posted Fri 30 Jul 10 @ 9:19 am
+ 1 Shure PGX4 & SM58
Gary
Gary
Posted Fri 30 Jul 10 @ 5:06 pm
exactly what I use
Posted Fri 30 Jul 10 @ 5:34 pm
im with the lads.
http://www.thomann.de/ie/shure_pg24epg58_t10_vocal.htm
have used this mic for roughly 3 years now and no antenna and good performance.
also have a senh cordless mic which ive got several knocks so the singers get that one lol
Posted Sat 31 Jul 10 @ 3:07 am
djstaffy wrote :
im with the lads.
i had a feeling everyone would suggest that. i was looking at the exact one. its $589 over in Australia.
Just curious, is it worth while getting the dual receiver models? I was thinking possible one handheld microphone & a lapel microphone or maybe dual handhelds... Flexible option with corporate stuff I guess.
Also is it possible to buy additional microphones/accessories and tune them into the same frequency and use them?
Posted Sun 01 Aug 10 @ 6:19 am
Wireless mic's without antennas (From the same brand) has less signal range compared to the ones that do have. It could be 50-100 feet
Posted Sun 01 Aug 10 @ 1:30 pm
I have a Sennheiser I purchased 8 years ago and its still going strong..
It gets moved constantly between my main system and my 'ceremony mini-system', not cased, just thrown in a tub..
I've never removed the antenna's (though you can, as they use a standard BNC connection)
I guess my point is, your problem isnt so much the external antenna's.. its the fact they are CHEAP external antenna's and components.
IE: you get what you pay for! it was a $700 cordless mic (at the time), but I must say its paid for itself many times over..
Also, another good thing about cordless systems that use the external antenna's with a BNC connection..
you can extend the antenna! or replace it with something bigger.. (IE: by raising the antenna up or using a directed antenna you can increase your distance by as much as 4 times! )
Posted Sun 01 Aug 10 @ 2:19 pm
