i see that it say vdj basic does not have support for full window. does this mean that it will not create a 2nd window for video and karaoke or does this simply mean that i cannot activate a 2nd video screen in full screen mode? i'm very confused and would like to know the difference before dropping an extra 250 dollars on something i won't need like controller support. i'm a small venue dj and just want to drag a karaoke window onto a 2nd screen, full size is not needed.
Posted Mon 26 Jul 10 @ 9:44 pm
https://virtualdj.com/products/comparison.html
you have no output video in full screen!
Braenzu
Braenzu
Posted Tue 27 Jul 10 @ 2:03 am
i get that i don't get full screen. can i still use a window though for vids and karaoke?
Posted Tue 27 Jul 10 @ 8:59 am
only on the desktop where the software runs (ms-windows)
Braenzu
Braenzu
Posted Tue 27 Jul 10 @ 9:03 am
If you have setup Windows for dual display (Extended desktop), then yes you can drag the video window over to the external display.
The maximum size of the window may be limited though.
Posted Tue 27 Jul 10 @ 1:06 pm
It will fill the screen but it keeps a small border round the video. Its not a major problem I used to find when using LE.
Posted Tue 27 Jul 10 @ 1:47 pm
